That is not an issue with the Real Sense, that is user error. You need to read how it works and understand what it can and can not do. Your H520 does not use the Real Sense. This tells me you need to learn how your H520 works properly before you take it up the next time. I know that a few others on here have mentioned it to you, but there is a steep learning curve with Yuneec vs how easy a DJI product is to use. That is the reason why so many buy DJI, it's a no-brainer to fly. Yuneec UAV's are a
That is not an issue with the Real Sense, that is user error. You need to read how it works and understand what it can and can not do. Your H520 does not use the Real Sense. This tells me you need to learn how your H520 works properly before you take it up the next time. I know that a few others on here have mentioned it to you, but there is a steep learning curve with Yuneec vs how easy a DJI product is to use. That is the reason why so many buy DJI, it's a no-brainer to fly. Yuneec UAV's are a lot more advanced.
Well, luckily I was smart enough (in spite of apparently being too dumb to fly this drone in some people’s opinion) to buy an extended warranty. Maybe if there was more than general knowledge in the owners manual and more structured training available besides a few videos on you tube the learning curve would actually be “steep” instead of pretty much unreachable. Thanks!
