- Joined
- May 27, 2017
- Messages
- 39
- Reaction score
- 8
- Age
- 52
I took the Q500 4K out last night for the first time in a month, with newly charged batteries. Turned on the controller and waited for it to acquire satellites. But when I turned on the Typhoon, the Typhoon repeated a series of beeps indicating an error with initialization. I switched batteries. I turned the aircraft off and waited. Same thing every time: initialization error. At one point the controller said there was an error with the fifth motor and to land immediately.
I tried rebinding the Typhoon with the controller. I tried recalibrating the compass. Nothing worked.
Finally I reset the controller to the factory settings. When I turned the Typhoon back on, it was normal. The engines started and I went on a flight. Everything was fine. When the battery started to run low, I landed, put a new battery in, and had another successful flight. But when I brought the Typhoon in, put a fresh battery in and tried to take off, the initialization error returned.
I have the Typhoon connected to the PC right now with GUI. The GUI is showing an ESC error with Engine 2, which is odd, considering I haven't had any crashes since the Typhoon's maiden flight last May (it drifted into the case about 2 feet above ground).
But sometimes when I reboot the Typhoon while connected to the GUI, the GUI indicates Engine 2 is OK but Engine 3 is not. When I try to reassign the motors, Engine 1 assigns correctly right off. But Engine 2 does not and I end up getting an error for Engines 2, 3, and 4.
I just unplugged the dongle, turned off the Typhoon, reconnected the dongle, and turned the Typhoon back on. Now the GUI says Engine 3 is faulty.
Any suggestions?
Any suggestions?
