- Joined
- Oct 30, 2016
- Messages
- 1,202
- Reaction score
- 440
- Age
- 48
Has anyone here tested what this "Support for dynamic Return to Launch depending on the battery capacity" is? Like, how does that work? I did not notice any changes in the menu.
My interpretation is similar to what you write in the second part of your post - I think it means that the copter will try to estimate how much battery it needs to get back to home point based on distance, and will alter the battery voltage level at which battery failsafe RTL will be executed. Similar to DJI.
I will be making some test flights soon, I'll try to cover that.
I reached out to a tech support rep at Yuneec asking for an explanation of what dynamic return to launch is. His reply was:
Dynamic return to home will cause the H520 to fly back and land at a spot that is 13-26 ft from where the transmitter was located at when the RTH function was activated. This is in contrast to Return to Launch, which returns to the same spot it took off from, and is best used in situations where the pilot will be moving away from the launch point during the flight.
