Pan dial off
Murray Martz
Premium Pilot
My st16 pan dial is off by 7%. I have read everything on here and nothing works. It worked for the first few flights, then went wonky. There should be a simple factory reset but nope, something like....RESET TO FACTORY. When I rotate the dial from the far left to center, it beeps at the detent as meant to, but when I do the same from the far right to center, it won't beep at the detent till I go slightly left past it
Included are two images ( not the best, sorry for the tilt ). 20170318_225244.jpg20170318_225542.jpg
Taking any and all help.
Murray
Follow the directions in this post and it should fix your problem. Read it carefully and be sure to set the sliders to the middle position.
ST-16 Calibration ( secret menu )
Steve, I read them all before I posted. I even tried that one a few times before the post. There has to be a way to do this better. Nothing has worked at all. It's just so odd that there is not a factory reset for the radio. You'd almost think that doing a factory reset on the tablet would reset the radio.
SamHembree
