- Joined
- May 9, 2017
- Messages
- 9
- Reaction score
- 1
- Age
- 58
Tips and/or Advice on ESC desoldering my Q500 motors;
I'm currently rebuilding my Typhoon Q500 4K due to a pilot error crash, ya I admitted it, was a dumb *** and flew at night over a 55ft tall tree and clipped the peak which resulted in a 55ft branch-to-branch tumble...ouch! (effectively busted off the RF motor mount arm on the airframe completely, glued it back on with Gorilla Glue Epoxy which held impressively however it resulted in a repair that had about a 1.5° degree pitch on the prop, essentially making normal flight (even with full pitch correction maxed out) impossible, with it constantly turning leftward slowly, landings and flight became dangerous and too risky to fly even in zero wind. Ordered a new airframe and now desoldering the ESC and power wires to the motors... now my PRIMARY QUESTION is;
1. What's the easiest way to accomplish this task. Should I desolder at the ESC board under the motors (or) desolder the lines from the main board? (The main board solder points/contacts are much smaller than the ESC board points, I'm assuming this would be the easier route but would like some pointers on this from folks that have done it before.
Also my first ESC wire I desoldered (a RF black one on the motor ESC board) resulted in needing too much heat and the tiny triple wire ESC plug housing dropped off the ESC board, which is micro soldered or solder pasted on... not looking forward to this repair either lol, but I have accomplished rebuilding a couple of Hubsan H501S and H501C 500mm quads successfully, I'm no electronics expert but can be handy, most of the time lol.
Thanks in advance folks for any tips/advice!
