So far as I know, the only difference might be the video range and that would only be due to the patch antenna. With stock equipment on one of the very first H's produced, I could get over 3000' with a very clear line of sight and no interference. I never fly that far anyway, but I did test it in a remote setting. Realistically you will loose video signal in many areas with trees or buildings and an improved antenna on the 5.8GHz side helps greatly.Is there a range difference between the typhoon h and the h pro?
Apart from the differences obtained between the square antenna and the mushroom antenna there would be no discernible difference between the H and H pro. A greater factor in range lies with the firmware...whether it is the EU firmware or U.S firmware: EU firmware is more limited regarding control range.
I stated 200mw and 100mw as this is what Spektrum radios produce. Yuneec may make Spektrum radios so I am making an assumption.
As best I can tell searching the web, Spektrum is owned by Horizon Hobby which is a US corp headquartered in Champaign, IL. Design and manufacturing of the RC gear however may be done anywhere as that is not something I could find.
I've found that in the US the FCC allowed 1W in the 5GHz band for WAP in 2014 or 2015. That may not expand to other uses though. It may also be something to keep in mind if operating in urban or indoor environments.
Here's are pretty good links on the channels, etc.
U-NII - Wikipedia
List of WLAN channels - Wikipedia
Yuneec does manufacture Horizons products, just can't be sure which ones.
Yuneec International - Wikipedia
They doYou assume they make Horizon products.
You use Wikipedia as a source. You think Wikipedia is a source for facts?
Wikipedia is an open community, say a forum. The hefty looking references are more then once just an article, like in your school's newspaper.
Ah.
Assumptions by some people are worth more or more credible then assumptions or deductions by other people?
Interesting.
