Spare parts
Brisbane Australia
Here is a list of spare parts that will be released shortly.
I'm hoping to have most of them available.
Item Number,Product
YUNH520101,Quick-release Propeller A: H520
YUNH520102,Quick-release Propeller B: H520
YUNH520103,Tri-color lampshade: H520
YUNH520104,USB to Micro USB Cable: H520
YUNH520105,5250mAh 4s/15.2V(79.8Wh) Lithium Polymer Battery: H520
YUNH520106,SC4000-4H Balancing Smart Charger: H520
YUNH520107,SC4000-4H Balancing Smart Charger: H520(for CN)
YUNH520108SVC,"Upper Cover: H520
(Authorized Service Use Only)"
YUNH520109SVC,"Bottom Cover: H520
YUNH520110SVC,"Internal Bracket: H520
YUNH520111SVC,"Folding Arm Bracket Component A: H520
YUNH520112SVC,"Folding Arm Bracket Component B: H520
YUNH520113SVC,"Motor Rear Cover: H520
YUNH520114SVC,"Landing Gear Connecting Board: H520
YUNH520115SVC,"GPS Compass Board: H520
YUNH520116SVC,"ESC Velometer Circuit Board: H520
YUNH520120SVC,"Motor Component: H520
YUNH520122SVC,"Motor Lampshade Puller: H520
YUNH520123SVC,"Switch Board: H520
YUNST16,ST16S Personal Ground Station (for INA)
YUNST16S100,8700mAh 1-Cell/1s 3.6v LiTon Battery: ST16S
YUNH520119SVC,"SR24 Receiver: H520
(US Version)
YUNH520121SVC,"Tri-color Light Circuit Board: H520
YUNH520117SVC,"IMU Module: H520
YUNH520124SVC,"Base of quick-release propeller A: H520
YUNH520125SVC,"Base of quick-release propeller B: H520
YUNH520118SVC,"SR24 Receiver: H520
(EU Version)
I noticed that there are parts still missing?
These are noted in the maintenance guide.
Landing gear actuators
Gimbal vibration dampers
Gimbal vibration damper locks
Gimbal rail
Landing gear feet
Leg locks
Battery connection board
Arm locks
Arm springs
H520 Internal cooling motor
ST16S Ground Station Control fan
Thank you for the information Haydn :)
Many pieces come with "Authorized Service Use Only". Has it been clarified who or how will the technical services be? A lot of trouble lately on this subject.
I'm not sure in USA.
But it should be me here in Australia.
So all my customers and anyone buying from myself or a reseller of mine will go through me.
Reactions: journeyman
It's good to have someone else in the forum who works in support :)
Many doubts and problems are solved in the forums and no time is wasted sending the drone to repair.
Thank you
I told you, I sent the E90 to my dealer for a malfunction when reading the SD card. From Yuneec Europe I have been told to send it to the nearest distributor. They didn't tell me to send it to the dealer where I bought it, the nearest one. I think you understand what I mean, I don't know how it will be, I just tell you.
Haydan on the second list some of the part you listed as still missing are technically not the h480 covers most of them. only H520 Internal cooling motor,
ST16S Ground Station Control fan ,Battery connection board, Gimbal vibration dampers,
Gimbal vibration damper locks, and Gimbal rail are whats left missing. in the USA that is. on your first list only the main h520 battery and props a and b can be purchased now.
We do it in the USA, and a few others some of whom are sponsors here.
There should not be an issue with parts/repairs/sources in the USA.
Reactions: Haydn
I have confirmation that I will be the service agent for these in Australia.
Servicing and repairs will be available.
Haydn
Reactions: arruntus
Item Number,Product
(US Version)
(EU Version)
I want that GPS Compass Board. Please contact me when available. Matt
Sacha
