And the channel output display still displays two channels moving?
No, no out of place. Everything is on place. Potentiometers are not fixed and you can slightly move them with fingers. Especially these for horizontal stick movements. This is known issue for ST16. This small movement alter the calibration process and overal stability.Inside of controller is intact. Nothing appears loose or out of
Place
This is something I haven't seen. Give me a while to try to create the issue.
Please confirm for us that the Flight Mode is selected to MODE 2 as in @DoomMeister's picture above.
Would you be willing to send the controller to me?
Does any one else recognize this issue? Please note the two affected channels are on two different sticks.
I thought clearing the data was one of the steps in the factory reset, or am I thinking of a firmware update?It is the first I know of that mixes it's channels, but does not show the mix in channel settings. I hope to find something that can be "user repaired" over the Forum. I worry that it may just be a "swaptronics" project to replace a defective component. At least we will know the component.
He has a couple more things he can try before sending it (clearing APP data and a full reload of the firmware update). I guess there is a chance one of those might correct the glitch.
Check "Rud"
Check "Rud".
