Typhoon H New Siuation
I had a new minor problem,which is now fixed I hope.
Last week I landed my
T-H . Not a perfect landing,but anyway I noticed it was beeping rapidly. Last flight of the
day. Did not think to much of it till i went to
Fly it a week later.
I fired it up and got the series of fast beeps again.
So no way was I going to fly it. I took it home and started investigating.
It seemed to have lost connection with my controller. I then did a factory reset on my controller, rebinded everything.
So it appears things are
back in order. I will know when I test fly it tomorrow. Anybody ever experience this
situation ?
Keith Kuhn
Have you checked the hardware monitor of the ST16? It might only be the stick calibration. If you see an offset, this is very likely to be the case.
I had this issue quiet early when I got mine. It is a very fast beeping with a constant length. It does not stop but just keeps going until you arm the Typhoon. It does not really fit to you assumption that they lost connection but I strongly recommend to give it a try.
Reactions: KEITH KUHN
It's too late now because I already rest the controller.
But I will be keeping a close eye on things.
I did notice after the reset
My landing gear would not
retract but I fixed that (upside down trick)
I am going to do a complete recalibration and go for another test run tomorrow.
Thanks Keith
Just type “22” in the page number selection box at the top of the PDF window...
I was looking at the paper manual that came in the
Box or carrying case.
It is a little white fold up
Sheet. I will check again.
But anyway I has 2 flights
after I did my controller
reset.On the second flight
Upon landing the rappid beeping returned.
So I will now look into
my joy sticks and anything
else I can check to try to remedy the rapid beeping.
Thanks
Keith Kuhn
Skowi
