Typhoon h plus st16+ Interface !!!
the ST16S?? Is that not the same as the ST16Plus or do i totally have the name of it Wrong? lol
a lot has already been said, maybe that will help you differentiate optically
ST16S has a further USB on the left side of HDMI, the ST16 ( ST16+ ) not.
ST16S Battery Pack is removeable total with the Black Frame and closed in a System Unit with connectors, the ST16 (ST16+) has a Battery with cable and a battery cover.
ST16S - the handle is fully plastic in black, the ST16 (ST16+) you see metal and plastic.
ST16S Display is different to the ST16(ST16+)
..i noted that i did not wrote . so i would still have one more ...
the most optical (Panel labeling) important (H520 ST16S ./. TH plus ) is:
H520 ST16S has "MANUAL", "ANGEL", "HOME" Option on S4 ( Toggle switch lever )
TH plus ST16S has "SPORT", ANGEL, "HOME" Option on S4 ( Toggle switch lever )
hope this helps
mymedease
