The last time I flew ( a few weeks ago ) my right side control (J3) wouldn't work now I can't get my typhoon H to respond at my ST16 at all. screen says ready to go but none of my thumb controllers work. WTF can anybody help me
DO NOT CHANGE SETTINGS!
On the ST-16 select Channel Settings.
Put the Rate Control Slider to full rabbit.
On the right you will find the channels, select Chan. 2. You should see J4 light up on the left for Aileron control. As you move the right stick to the left the value at the bottom center should read 0% to 100% at full deflection, and 0% to -100% as you move to the right.
Now select Chan. 3. J3 should light up on the left for Elevator control. The values at the bottom center should be 0% to -100% as you pull down on the right stick, and 0% to 100% as you push up.
Exit Channel Settings by pressing the Back Arrow. Report the results from viewing the Channel Settings for the right stick.
Select channel 3 or did you mean “select elev”, sir Doom?
Best to be precise when dealing with channel settings.
Jeff
It is actually either one, but the bold type is “Ele” and “Ch3” is in lighter type at the upper right of the soft button.
You are very right about being precise when dealing with the Channel Settings Jeff! Thanks for having me double check myself.
Another option is to create a new profile and once bound, see if everything responds the way it should. Had a problem with one of my H's where things were not responding properly. Tried lots of things to fix the problem, in the end creating the new profile fixed everything.
I learned something too, DM! I never noticed the channel numbers before. Hence why I was keen on differentiating between ELEV and J3.
Wow! I see them now. Good thing I have updated my glasses!
Thanks Doom!
Jeff
They are hard to see with polarized glasses on.Or snow blindness. [emoji16]
Well I contacted Yuneec they replied with this emailDO NOT CHANGE SETTINGS!
