Checklist (Add your bit to it)
POST #1
Hello everyone, I am writing this post to gather everyone and come up with a complete checklist for our Q500 4K drones. I will be editting this post as people add things to it. And, once we have a FINAL checklist, I will lay it out in a nice .pdf file and will share with all of you, so that you can print it and use it correctly.
The checklist must include the following stages:
*Pre Take-Off
*Post Take-Off
*During Flight
*Pre Landing
*Post Landing
Check following post for the start of the checklist itself ------>
Reactions: greatbear1968
POST #2
● Pre Take-Off
□ ST10+ has SD Card installed?
□ CGO3 has SD Card installed?
□ ST10+ Battery fully charged?
□ Compass calibrated?
□ Accelerometer calibrated?
□ Desired model selected?
□ Mode set to "Angle"?
□ ST10+ GPS acquired? Enough sats?
□ VOLTS higher than 12.4v?
□ ST10+ monitor checked?
□ Start motors, no weird noise?
□ ALT within reasonable reading?
□ G-SPD within reasonable reading?
□ DIS within reasonable reading?
□ White Balance (WB) set?
□ Exposure Value (EV) set?
□ Photo/Video switch set?
□ Camera settings are correct?
□ Camera is recording?
□ Status light is purple?
"You are clear for take off"
● Post Take-Off
□ Double check for motor noise.
□ Double check for status light.
□ VOLTS dropping reasonably?
"Everything good, fly safe..."
● During Flight
● Pre Landing
● Post Landing
I'm updating...
Not trying to downplay your effort, but there are at least 2 Q500 check lists here already. Do you not like them?
Not that... I think if we do a formal one in .pdf format, people will print and carry. I will do my best to create one that covers most of the procedures, but I bet I will forget stuff, thats why I'm calling everyone to cooperate and help create a FINAL version with all the checks necessary for a safe and satisfactory flight.
I use to fly single engine land airplanes and my check lists weren't that extensive. o_O
mbecks
