Control CGO3+ gimbal
Hello Everyone,
I'm going to go on vacation soon and want to take the CGO3+ with me.
I want the CGO3+ on a custom build platform with the internals of the steadygrip. I want to be able to control the gimbal with the actual Typhoon H controller but I noticed I can't when it's connected to the steadygrip.
Is the CGO3+ gimbal controlled via the Typhoon H and via the SteadyGrip itself, or is it because there is already a "controller" connected (the scroll wheel on the steadygrip).
Do you think it will work if I remove the PWM pin?
(I won't actually have the plastic mold of the steadygrip, only the internal cable and hardware to make sure I don't break the CGO3+)
Have to make a guess here...........I don't think the camera tilt signal is on the 5.8GHz video signal. When the camera is connected to the H the tilt signal is coming from the H on the channel 7 which is through the 2.4GHz signal. Without the H, the tilt will only work if it's connected to the Steady Grip.
Bdog
