For those of you who do not want "smart mode" here is what I figured out this morning. I have already flown three batteries and it works like a champ. Be certain to write down your factory settings/percentages before modifying anything!!! Now, go have fun.
UPDATED STEPS (Much Simpler)
Seems all you need to do contrary to a few of the steps shown in my video are as follows and it will disable the "Smart Mode" until you decide other wise. It is working every time for me and flawless.
1.Tap Channel settings
2.Tap OK
3.Tap AO1
4.Tap S4
5.Tap edit
6. Change Pos.0: from Act to INH ( Reverse this step to gain smart mode feature )
7. Tap Save
8. Tap Return twice and your done.
To confirm you have successfully disabled the SMART MODE simply boot up you ST16 and H then switch between modes
RTH should be Red on your H's LED
Angle should be purple with white
Smart mode if disabled will be purple and white rather than green
2.Tap OK
3.Tap AO1
4.Tap S4
5.Tap edit
7. Tap Save
