- Joined
- Sep 29, 2017
- Messages
- 35
- Reaction score
- 2
- Age
- 69
Qualitative versus quantitative IR thermal data?
A qualitative IR camera is one that makes a comparative analysis of different thermal energy sources which is being displayed on the screen.
A quantitative IR camera is one that provides a specific temperature rating assigned to each pixel on the sensor which is then displayed on the screen.
These quantitative IR cameras are calibrated and designed to correspond to a specific temperature range when built and tuned at the factory prior to delivery. If your customer requires specific temperature data to be provided with their inspections then you will need to pay big bucks for this type of sensor package. In addition you will be required to fly your missions closer to the objects being inspected due to the physics of emissivity as it relates to thermal energy being read by the IR camera.
A more sophisticated customer who requires specificity and accuracy in the inspection report they are paying you to provide, will most often require you to show them your Thermography training certificate. This certificate demonstrates to them that you have been properly trained to professionally operate and setup the camera relative to physical and environmental circumstances so as to produce meaningful results with your IR camera device. In addition this level of customer will also know that your camera will have a calibration certificate and these certificates usually are good for a year.
Calibration of a quantitative IR camera requires a sophisticated test environment and highly trained engineers to perform this task. IR calibration services are most often a return to manufacturer situation and can cost around $1,000 or more.
Try a web search of the following phrase for much more information "IR camera qualitative versus quantitative"
The information in this thread is provided for anyone who is targeting customers who actually need qualitative IR thermal measurements obtained with your UAV. There is a big difference in flying a drone performing leaky roof inspections with a qualitative IR camera versus a customer who is requiring you to get up close to high voltage electrical power distribution systems and provide accurate temperature measurements for him on live equipment.
So if FLIR is working with Yuneec to provide a higher level of capability in the IR thermal camera options for the H520, then be prepared to realize what impact that will bring to your organization in terms of training and operational budget considerations.
