- Joined
- Jul 11, 2018
- Messages
- 66
- Reaction score
- 1
- Age
- 21
i mean samll parts like sensors card reader,motherboard would you be able to give an estimate of how much that would cost?
Can companies like vertigo drones repair this under warrenty or do I have to call yuneec first becuz' its almost impossible to reach yuneec tech supportIf the bottom part of the camera and housing is broken, it is only repairable at a dealer who does camera repairs. Replacing the boards will not fix the camera without a complete calibration and that can only be done by Yuneec or a dealer.
Yes the real sense box was checked and I was facing the tree BTW will yuneec pay for the drone damage since I added on this real sense myself?Did you activate the RealSense through your Controller when you added the RealSense Module onto your Typhoon H? If not, then the RealSense wont work.
Also did you crash INTO something or BACK into something, causing the crash? RealSense only functions for forward obstacle avoidance..
One other thing, it is expensive to have the lower half of your Camera repaired, including the parts necessary. And, it's been my experience that you should probably consider what you are assuming to be good on your Camera may also be bad.. A whack hard enough to bend or break the bottom half of your Camera could conceivably damage the boards in the top too. JMO
PS- Sent you a reply to this same question on the other Site you posted to.
Can companies like vertigo drones repair this under warrenty or do I have to call yuneec first becuz' its almost impossible to reach yuneec tech support ( I wouldn't be surprised if they only had one guy in there picking up phones![]()
