When does this happen, is it when it is connected to your PC? Props on or off?I've replaced the motor and then I replaced the entire board because someone said it was probably an ESC failure if changing the motor didn't help. Anyone have any idea why I am still getting a single motor malfunction?
All props are on. It originally had a motor malfunction while flying and I replaced the motor. Then the same motor would not start on take off so I replaced the whole board. It still will not fire on takeoff.When does this happen, is it when it is connected to your PC? Props on or off?
Replace the non-responsive one with one of the ones that works and rotates in the same direction as well as the ESC. This will narrow down the issue even more.All props are on. It originally had a motor malfunction while flying and I replaced the motor. Then the same motor would not start on take off so I replaced the whole board. It still will not fire on takeoff.
