Which model do i have?
Isle of Man
Hi all, i was given a typhoon H but how do i know if its an h plus or whatever? Doesn't say anywhere in the manuals.
Cheers.
Turn the aircraft so the nose is facing you... the model is embossed right by the power button... it will be either Typhoon H or Typhoon H Plus... also which camera do you have attached... the Plus uses the C23... the Typhoon H uses the CGO3+.
Reactions: hueman
another method is to use a metric scale tape measure. Measure from one motor to another on the other side of the aircraft. If motor center to center is 480mm it's an H. If 520mm it's a Plus.
Reactions: hueman
the easiest method is knowing that no one is going to give you an H Plus
Oh for sure! Not even @Steve Carr will give you one! ...So I've been told, and he's flush with 'em.
...Heck! I can't even get myself to give me an H Plus, and Christmas is almost here, and I've been a REALLY good boy all year! Oh please @Steve Carr er Santa please, Please!
ok, what size for an h Pro, I would assume the same as an h with Real sense, let him know that... so he knows
BengalFlight
