CG03 +
Need advise, just replaced slip ring and now my CGO3+ bleeps 2x long 1x short so its pitch yay thats now faulty so heres my question.
I have a CGO3 will the boards fit the CGO3+, or do I order new ones from Yuneec and hope this cures it.
Regards ??
The sensor boards are interchangeable, but the wire lengths are different. You can run the CGo3 wire directly from the pitch arm to the gimbal board (without threading it through the frame) to see it it cures the problem.
Of course, first make sure everything is plugged into the proper connectors, none of the existing wires are damaged, and all the solder joints are good.
A continuity check with a multimeter will show if any wires/solder is actually broken, and it can show if there is a short between wires, or from wire to frame.
Sensor boards do sometimes go bad, but it's pretty rare. It is far more common for the issue to be damaged wires or connectors out of order. If two plugs are reversed, you would expect to get two codes, but that does not always happen. It sometimes only sounds one code, and not the other. You can also use the multimeter to ensure each encoder is plugged into the correct board connector.
Yep i can confirm that, I switched over 2 connections and I got 2 sets of bleeps so I turned off drone, took out battery and waited q0 mins just to make sure.
Put back the connections to correct positions and start drone again and only got 1 bleeps.
So I will seek a yaw board and see what happens.
thegeniussquadofficial
