Crazy Camera control
So I took the camera off the drone to use the steady grip. The wires broke. I am using the jumper cable. Most of time I get a green light on camera. However the feed is purple or some other wierd color. Then it might be good for a few minuets. Today the camera light stays white and no Wi-Fi. I did factory reset several times. I cannot bind with the camera as it is not found. I see a wires shaped metal part under lenscover. One side seems to be loose. I put it back into a slot. Any help would be appreciated.
There are no exposed wires with the H's CGO-3. What camera are you referring to? Descriptions are rather important.
YC_yuneec
