Excellent Yuneec Customer Service
I have a Phantom 4 and a Typhoon H Pro. I love both. I have received superb customer service from Yuneec. Way beyond my expectations.
I do not like the fact that the H climbs to 10 meters when you switch out of Angle mode. I usually fly at low altitudes. This resulted in my H climbing into an overhead branch. I'd like to see an on/off options for the "climb" and/or a "set the climb to altitude" ability.
Anyway, the repair (very minor) cost me $80 plus shipping both ways and was a lesson in school of hard knocks.
I experienced SUPERB customer service from Yuneec. When I call them, I got right through to someone, and he was very helpful. I am NOT used to even FAIR customer service, so this experience made my day.
PS; I just placed an order for the Phantom 4 Pro today with DJI.
Thanks for sharing. Mine has never climbed when changing to Angle mode. Sure you did't select RTH in error?
Reactions: yuneec53
PS; I just placed an order for the Phantom 4 Pro today with DJI. <- SORRY TO HEAR THAT
Why, would you switch out of angle mode? Smart mode is for anxiety attacks!
It was changing OUT of Angle to Smart
I confirmed with Factory Customer Service that it's supposed to climb when switched to Smart (that's stupid in my opinion).
I can assure you that this is not correct. What person did you talk to in Yuneec Customer Service? USA?
Yes USA and I mentioned my suggestions to him as well. I had it in angle mode, hovered around to make sure everything was Kosher and then switched to Smart mode. It went straight up. If I goofed up and put it in RTH, that would explain it also. But the tech at Yuneec said that that was a safety factor to make it climb when switched to Smart.
I didn't play detective (and ask his name). As I said, we even discussed my suggestions about making this a user option. But, that all said, I am perfectly willing to consider that I did to a RTH. I doubt it, but it is possible. I will tray it again, from a safer place, and see for myself. Keep the "!!!" to yourself please. It was not necessary. Thanks for your input.
Is it possible you switched to smart when the H was inside 30ft of controller and it climbed to maintain 30ft "safe distance"?
That's most likely what happened! Thanks. I'll be more aware of this now! I suggest that Yuneec make this a user selection option, thoughts? Thanks again for hitting the nail on the head.
Reactions: Markinter
thierry2
