Connect the H to your computer with the USB charging cable and open the GUI to see if there are any error messages.I planted the H from about 40', landing gear down. Messed up gimbal and landing gear, couple props. ST16 will not connect to drone now. I'd like to test drone without the camera or gps and find what needs fixin. TIA
You can test the landing gear by turning the H up side down (with no camera or props) and cycle the switch. Of course the ST16 and the H have to be bound. Turn on the ST16 first and after a couple of minutes, turn on the H.Thanks for the reply. Only red X are IPS and Real Sense. All motors spin. I'd like to test landing gear. ST16 refresh and bind with no camera I get Please Select a Receiver.
Thanks again for the quick reply. No luck upside down, but re-bind w/o camera, turn off GPS fired up H. Landing gear works, but I need to replace legs. Prop motors spin, but sounds like a have marbles rolling around and goes into 5 rotor mode.
