Secret POT cleaning port on back of ST16
So after taking the 16 apart (again) to clean the pots I was thinking about drilling a couple of small holes above the pots for easy access and it looks like Yuneec already thought of this.....Tried it on a second one and it appears to work just fine.....Your Welcome......secret pot locations.png
Good find. Maybe those a drain holes for when you're flying in a downpour. :D:D
Our dear friend Vic Pete already had this thought.
Cool to know for certain. Just clean it with compressed air?
Those access holes are typically for adjusting stick tension. I have many Spektrum radios and have never cleaned the Pots, they are self cleaning just from being used. I have a recording studio and Pots that do not get used regularly can make scratchy sounds when rotated. The fix is to simply keep rotating back and forth until they wear themselves clean. If it still is dirty I use this....http://www.musiciansfriend.com/acce...Lw_wcB&kwid=39474984916x42814104161x151905500
marcojanson67
