ST 16 shuts off after first Yuneec logo
Hi There,
Having trouble with my controller. It will just shut down after the first "Yuneek" logo. Tried the sd card with the update.zip and the Yuneec-App-Release.apk to no avail. I have mashed the centre button when it starts and that didnt work either.
Any suggestions?
The first idea that comes in my mind is the battery. Maybe the voltage goes rapidly down when processor starts to work.
Is the loading icon present when you connect the loader with the USB?
I havent been connecting anything with a USB. Should I be?
How do you charge the battery if you don’t charge through the USB port?
So with a full charge on the ST16 you get the first Yuneec logo when you power on then it goes blank. Do I understand you correctly?
I don’t have any personal experience with this. Take a look at this thread H520 ST16 Controller Update seems to have KILLED my ST16. HELP!.
Power on the ST 16 and start tapping the center soft key at the bottom of the screen repeatedly. It should get you to a menu where you can select a reboot option.
Mine is not stuck in a loop and doesn’t respond to this procedure so I don’t even know what items appear on the Fastboot menu. When @Steve Carr or @WTFDproject they may be able to guide you further. There is another member @SilentR9 that is good at restoring bricked ST16’s.
Taking it one step at a time, it seems to be important both how and when you use the center button.
First part is HOW. You don't just press and hold. You have to tap it repeatedly. And it sees to be some magic tap rate somewhere between too slow and too fast. (I never actually had to do it either, so I can't give much help as to "how fast".
Second part is WHEN. The consensus seems to be that you start as soon as you power on the controller, and keep tapping even after the screen goes dark. I also don't have any basis for "how long" is reasonable, so just give it enough time to be convinced it is going to work. Then start again with a little different tap rate and see what happens.
If it actually works, it would be good to know about how fast and how long you did the tapping.
I was informed that the procedure I linked you to for the ST16S may not work with the ST16 (for the H480). Most likely the reason I could not get the Fastboot menu to appear on mine when I tried it. Hopefully @SilentR9 will notice your post and be able to help.
Reactions: IanWalker
I did at one point get the fast tab to succeed, but it just went into an update, shut off, and im back at the same place. I have tried the fast tap again many times, but i will keep trying. Maybe I had the perfect speed the time it worked?
  • Love
Reactions: Mike Irish
Did this happen just out of the blue or were you in the process of updating firmware?
Reactions: WTFDproject
Do you recall what firmware revision you were updating from and to? What instructions were you following?
Unfortunately I wasnt the one doing the update. My boss was and he has no idea :\
Download the 3 files from this link: ST16_V3.1.30
Copy them to an sd card which is formatted as FAT32.
Insert the sd card in the controller and then turn it on. Wait to see if it starts updating.
Do not unzip any of the files.
Should I have the three files in the folder ST16_V3.130, or three directly in the card?
And should I hit the middle button while it opens, or just turn it on and leave it?
Lessa2002
