- Joined
- May 28, 2016
- Messages
- 119
- Reaction score
- 54
- Age
- 50
There was twitch to the right for every waypoint. I think I counted 11 times.
I think the speed was set too high. A slower speed should make the waypoints less pronouced
One thing I noticed is when bound in 920 it is not as locked in. Drifting is more but more testing to see if it was just a bad gps lock day.
for people that would like to know .
you can go to your models and export the typhoon H model to the SD card .
then open the file manifest.csv thats on the sd card in excel on your pc .
it will look something like this .
fpv 1
version 1
name Typhoon H
type 401
etc
etc
etc
etc
i have noticed if you change the name to something like
TYPHOON H WAYPOINT
and change the type to 403
then select new model and import the changed file you will have
a new model titled whatever you named it .
if you select it . the waypoint editor now works and you have left everything else the same ..
Hi,So I don't know if anyone else has stumbled across this yet but with the new update we can now do waypoints.
Create a new model and select H920
Pair up your craft and camera (select cgo3 pro)
Now go to your task modes and you have waypoints.
Select it and it takes you to the waypoints editor
Enjoy!!
Seems to work well
Also like the way you can change the drone image.
On another point has anyone setup the Aux button with a function- I was considering setting it as a temporary HOME button it would be an easy way of confirming the orientation of the craft
Hi,
Are you saying you tried the H920 model by flying a mission?
Thanks
Think I'll wait for someone else to give it a try.
Are the instructions you got for the 920 Waypoints the same as outlined in the previous posts? Can you make a step by step summary here just for clarity?I only came to this because I asked John at Yuneec uk if it will ever be available for the H.
He gave me instructions so I'm fairly confident it works...
Have you flown the H with the 920 model profile? Does it fly the same as the 480 profile? Do the UAV Toolbox missions still work with the 920 waypoints?also, if the 920 is not on the model list Update ST16 to latest firmware.
Apart from that he said crack on.
So this method disagrees with the method posted by "Gurusonwheels"He said, select the 920 as the model and bind the H and use the st16 waypoints app. Done done and done.
